6 in hook an loop sandpaper recommendations http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=53191 |
Author: | Ernie Kleinman [ Wed May 06, 2020 9:40 am ] |
Post subject: | 6 in hook an loop sandpaper recommendations |
Hi I have a 36 in woodmaster single drum thickness sander. I still have several of the 80 grit paper rolls that came with the sander. Notice it tears readily . Would like something that lasts much longer . Particularly with ebony, rosewood, coco etc Changing paper is a pita.TNX in advance. Which brand are you using and what are your results.? |
Author: | Bri [ Wed May 06, 2020 10:07 am ] |
Post subject: | Re: 6 in hook an loop sandpaper recommendations |
I have the best results with the blue Aluminum Zirconia from Klingspors Woodworking shop. Never had a tear, but the burning can be an issue on the woods you mention. High feed rate and light passes are your friend. B |
Author: | meddlingfool [ Thu May 07, 2020 8:57 am ] |
I use a company called FinTech. Quite inexpensive... |
Author: | Ken Lewis [ Thu May 07, 2020 9:32 am ] |
If it tears easily it's probably not best suited for drum sanding imo. I've gotten good quality, good price, rolls from Supergrit in Pa. I don't use H&L but they are available here. https://www.supergrit.com/products/prod ... msleeve-hl |
Author: | Ernie Kleinman [ Sat May 09, 2020 6:47 am ] |
Klingspo/s wood shop .is the only one carrying the alum blue zirconia rolls |
